Overboarded existing floor boards with 18mm ply. Due to the width of the hallway varying decided on centre point which looked correct from doorway. Marked with string and started with first diamond tile in centre and made cuts in sections to ensure all fitted correctly. Tiled again in sections using rapid set flexible adhesive. The job did take me considerably longer than anticipated but very pleased with the end result. Not bad for only my second ever job !
