You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
cast after de mould made from powered sand stone jesmonite this is hollow cast for wiring for electric gate censer step 8 | Tiling Advice | TilersForums.com | Images & Downloads - TilersForums.com
william_cee
william_cee
I know this is not tile work but this material was also used to demonstrate the strength of jesmonite in terms of making shop signs to have cut into tile work a bit like a big insert can be made from it. It can be polished smooth or it can be kept rough textured to give the effect of sand stone.
