Discuss Removing wooden floor from underneath kitchen cabinets. in the UK Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
Went to view a kitchen yesterday.
The kitchen cabinets are sitting on 15mm solid wood flooring. The flooring is bulging in the middle of the floor. I believe this is caused because the heavy kitchen is sitting on the wood and the wood has nowhere to expand to (except upwards). Customer wants wood removed (about 30sqm) and replaced with UFH & 600x600 porcelain tiles. My problem is how do I remove the wood flooring from around and under the cabinets? I have found a tool called ‘Toe kick saw’ but it only seems to be available in the States. Also, I believe it is quite a dangerous tool to use. This tool will cut upto ¾ inch in depth and will cut right up to the cabinet. Is there anything in the UK that will fit the bill. The kitchen cabinets are solid wood really expensive with granite work surfaces. Cheers Sean
Sean Kelly
1,068
Ruislip
wouldn't it be easier to have kitchen removed if you go cutting the floor theres a chance the kitchen will sag
It's a really big kitchen Jay, but I do know what you mean. cheers.
Sean Kelly
1,068
Ruislip
P1020075.jpg P1020074.jpg Cutting to just behind the kickboards should not be a problem. The problem lies with the parts of the units that are on show i.e. the pillars and the sides of the breakfast bar and fridge. I may have to go back and have another look underneath the units.
Sean Kelly
1,068
Ruislip
Sean would a fein not be able to cut around the posts? might be a daft answer sorry if it is.
chris
Chris, It's probably not a daft answer, a fein is one of the few tools I do not have in my collection. I bought an exakt DC270 at the Home Show a few weeks ago.I have used it for cutting kick boards with perfect precision - brilliant tool, but no good for this application. Can a fein cut into 15mm hardwood? Cheers Sean
Reply to Removing wooden floor from underneath kitchen cabinets. in the UK Tiling Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Hi all, I'm new to this forum. My business is a handyman. Often this includes small tiling jobs...
Hi Guys, I am new to this forum and I'm an "experienced DIYer" if I can say that :). We (my...
Sean Kelly
Ruislip
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
