Diamond Pool Finishers
i have been using original-syle a pool blend, the mesh backing looks a little like there is to much of it !, they have taken on board the problems with water soluble mesh adhesive, But this has lead on to another problem,as these cheaper blends have issues with there squareness as sheets they are usually warped in one or more corners ,which is not a problem with the old water soluble blends, as when they are laid in wet tile adhesive the mesh on the backs relax and you can return a few moments later and massage them into straight lines, but with the new waterproof blends they stay out of square so the only way is to slit the mesh in -situ then massage them into place, and this is very annoying time & time again on a big job ,you start to question why the manufactures can't produce a mosaic that is square !!:mad2: how can we relate this back to the far-eastern makers ? so they can do something ?
