Discuss Replacing tiles in a shower cubicle in the Tanking and Wetrooms area at TilersForums.com.
James De
so I’m replacing an exposed shower valve today. Only snag is they had a really crap valve in before which is piped up with services far left of the valve. One of the tiles I need to remove is behind the curved screen which looks old and decrepit and I just know as soon as I remove it the can of worms will open up.
Is there any way of replacing the far left tile without removing the screen?
Boggs
1,118
Uk
I have had a similar situation to this before, what I did was use my Hardie scoring knife to score the tile surface tight to the enclosure then carefully break the tile out with my hammer and an old screwdriver after removing the grout.
Worked well for me and left a decent straight edge I could tidy up with a file.
I left it as a grout joint when fitting replacements.
James De
Mine has ended up like this :mad: I was thinking of putting a couple coats of SBR over it, filling it with rapid flex and then tiling into that once dry???
Boggs
1,118
Uk
There seems to be quite a depth to the brickwork.
I think I would chop out more of the render to make it squarer and dot and dab some plasterboard in if possible.
James De
How come you’re using wall plate elbows?
Is it a bar style valve going in and you’re using the cranked adaptors?
Because the stupid shower they’ve bought isn’t compatible with the bar shower fixings that you can fix to the surface of the tiles :mad: yup, it has crap offset adapters as the valve has an internal filters you can’t remove that fit inside the offset adapters
Reply to Replacing tiles in a shower cubicle in the Tanking and Wetrooms area at TilersForums.com
Hi, Can anyone please give me some advice. I have an old bathroom and I want to turn it into a...
Hey. I doing my first walk-in tiled shower. The shower is 4’x8’. Most of the floor is covered...
    Votes: 9 6.0%
    Votes: 14 9.4%
    Votes: 11 7.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 2 1.3%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
    Votes: 7 4.7%
