Discuss Can you spot the error in setting out for wall tiling in this photo? in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
5,039
1,323
Staffordshire, UK
TimelessJohn
Subscribed
OMG Teej!!!!!
Welcome back my friend. I've removed ads for you and given you arms access etc
Welcome bloody back my friend.
That is much appreciated Dan!
Hope you and your good lady are well.
Looking forward to helping any way I can.
Still enjoying the best trade out there.
TJ
Was DIY to be fair to them. Didn't see the wall fully though so maybe some weird reason why it's such a slither there but no excuses really.
I've seen far worse from a "professional". I once rented a house and the nice tiles in the shower were loose. The agent sent a professional tiler around who ripped off all the tiles and replaced them with cheap plain white. They wernt levelled and Instead of setting setting out correctly, or even cutting thin strips, he filled 2cm wide gaps with grout. I sent photos to the agent. Felt sorry for the owner who was a serviceman based overseas. I'm not a professional tiler but I can do far better work myself, it just takes me a long time.
Tile Marble Granite
The small tile cuts look bad on the wall, the PVA strip too short to cover the gap entirely. The box/shelf looks like it is lower or level with the tub and no pitch down, the water sits on top of the tile and no overleap to overcome the gap. Most likely the bathtub was installed after the tiles were done creating those gaps around it. Bad practice!
Reply to Can you spot the error in setting out for wall tiling in this photo? in the UK Tiling Forum area at TilersForums.com
  • Sticky
  • Question
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few ways to fix tile to bathroom walls. First you need to prepare the walls for tiling. Note that...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
  • Question
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
