Guest viewing is limited
Discuss 10cm x 10cm square wall tiles in a brick layout? Yes or no? in the UK Tiling Forum area at TilersForums.com.
MissH
Hi all,
Bit stuck on getting the right pattern for tiling my kitchen walls. I've chosen the tiles finally and they are a slatey effect in 4 colours. I loved the mosaics but were too expensive! Anyway so the tiles don't look boring I thought about getting the tiler to set them in a brick layout. The tiles would go up to the bottom of the units and in an "arc" shape up to the glass on the chimney hood (what do you think about this? is this difficult to do?). Wherethe breakfast bar bit is reached I thought only 2 rows of tiling - one looks a bit twee and old fashioned! I would like to edge exposed areas with chrome.
Question is can brick layout be done with multi coloured tiles? I've put photos on Flickr so you can see the tiles and layout of the kitchen? Are these tiles better suited to a simple square layout?
Flickr: Huckelberry67's Photostream
How much more difficult is to lay brick style? Will I need to order extra? What should I ask the tiler about?!
I've decided to only go with 4 of the 5 colours of the tiles - the very light one again looked a bit old fashioned mixed in so prefer just the mix of four.
Thanks for your help!!
MissH
Thanks and sorry for the gigantic text! Not sure what happened there! I do know what you mean...maybe if the tiles were one colour brick layout would work but I do like the mixed colours! Teh simple layout does actually look better in the photos to be honest sp pleased I took some. I'm also a bit worried that it might be tricky to lay out brick style around the bit that sticks out from the breakfast bar.
Bubblecraft
I'm not a fan of brick bond on 4 x 4's. It can sometimes end up like this depending on the tile. I know this isn't centre but it can still happen
Reply to 10cm x 10cm square wall tiles in a brick layout? Yes or no? in the UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
