10mm LSF cable for shower Discussion Thread10mm LSF cable for shower Electrical Advice
Hello all you fine folk and hope you're all keeping well.
Having a bit of a dilemma here regarding making off 3x10sq LSF cable for a shower. I'm debating about about whether to use a crab tree pull chord or to just mount a 2 gang 45/50A shower switch. Shower rating is 9.8kw with cable being clipped direct to timber joist in attic. I don't want to rule out the possibility that the cables could be covered with Insulation at a later stage, as it is a new build and I've asked builder to keep the cables as free from Insulation as possible.
I saw this topic was discussed on the forum before, but I don't think it was the LSF cable being used, which makes my life even harder. I have made off 2x 10sq lsf cables into a crabtree pull chord before which was a huge pain in the a*se. I have also made off 10sq cables for cooker switches before into deeper 2 gang metal back boxes, which, again wasn't fun.
But as this was some time ago, I'm just wondering has anybody come across any new accessories that would make it any easier to terminate these cables? Or is it just the same story of sheer finger strength and heartache? If those are the only options still, what are people's preferences?
10mm LSF cable for shower for the original thread on Electricians Forums
