Discuss 12v Auto circuit solution sort! Dodge Ram1500 Electrical Advice in the Electrical Advice area at TilersForums.com.
12v Auto circuit solution sort! Dodge Ram1500 Discussion Thread12v Auto circuit solution sort! Dodge Ram1500 Electrical Advice
Dodge Ram 1500 Gen 4 rear lights conversion (CAD import); Problem. When I brake my rear brake light come on but so do my indicator lights (they don't flash at this time). So I have a wire along it travels a brake signal and a turn signal, when either of those functions are operated. This wire currently is used as a turn signal. I want to shut all current off along this wire when the brake pedal is pressed effectively shutting down the indicator. When the foot comes off the pedal the indicator can work again. So is there some kind of diode that only blocks when energised. Thinking I take a brake signal from a brake secondary circuit to energise the blocking device. As a mechi that's the best I can think of but what can do that. Anyone?!!
12v Auto circuit solution sort! Dodge Ram1500 for the original thread on Electricians Forums
Reply to 12v Auto circuit solution sort! Dodge Ram1500 Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
