Discuss 18 or 25mm plywood subfloor in the America Tile Forum / Advice Board area at TilersForums.com.
Some advice would be greatly appreciated! So I'm putting in wet underfloor heating and limestone tiles in kitchen/living. The underfloor heating pipes will be laid inside 20mm routed cement coated xps board which can be tiled directly on top off. My question is, would an 18mm plywood subfloor (directly on joists) be adequate, or should I go for a 25mm subfloor? The joists are at 400mm centres and will be strengthened with noggins. Thanks in advance!
Reply to 18 or 25mm plywood subfloor in the America Tile Forum / Advice Board area at TilersForums.com
Hello. We're going to be installing large limestone tiles with wet underfloor heating in our...
Hi everyone, I'm having the majority of the ground floor of my house tiled (35m²) and I'm not...
Bit of an intro - I'm a competent DIYer and have been refurbing the bathroom on and off for the...
6K
L
Hi, I am building a new bathroom in my own house. The room is on the first floor in a newly...
Hi all, I've put water underfloor heating down in our bathroom using "ProWarm Warm panel" which...
5K
J Sid
USA Tile Forum Popular
America Tile Advice Trending
Edinburgh, City of Edinburgh
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
