Tiling Tool Suppliers
Discuss 1mm cut off disc other uses in the Tiling Tools area at TilersForums.com.
Albert
1,253
Gateshead NE8, UK
I use these for metal trim.Any one used them for ceramics?
Some company's no dought can be a little economical with the truth, if it's no good for ceramics then perhaps someone should tell them.
It's not actually that cut and dry, I don't suppose. Like porcelain, there are different grades.
And all porcelain blades behave differently with different grades of porcelain.
Same could be said of ceramics.
So if what they tested their blade on cut with an acceptable level of success, then from a marketing point of view, they can put ceramic on their blade.
Pretty much in the same way Hardie state their boards are impervious to water.
If you take the word impervious at its primary explanation then it's a blatent lie.
If you put in to the context of its secondary meaning, then Hardie, is indeed impervious to water.
But with a professional, common sense should warn you that a cutting blade could not possible as successful with steel as it is with ceramic. It just couldn't be. But if you're a diy'er, then the performance of the blade isn't probably so important, so therefore they may well be more accepting of a low quality cut.
So it passes for as it says a multi purpose blade.
It does what it says on the tin!.
As long as you don't have high expectations. :)
Personally, I use a different blade for every material type.
Experience has shown me that if you use a blade on porcelain and then on a subsequent project use the same blade on stone, the next time you use it on porcelain, it won't cut with the same high level of finish. Swapping between materials with the same blade only impedes its performance.
Ergo....a multi purpose blade, will never have a high level of finish on any material, just a passable one.
You wouldn't necessarily have high expectations from a multi purpose blade, however they have there place. They are not claiming to be a high end product.
Well this is where your 'fit for purpose' statement comes in isn't it.
'Fit for purpose' is a purely subject statement. What's 'fit for purpose for one person, is a pile of rubbish, for someone else.
IMO it certainly wouldn't be 'fit for purpose' in my tool kit.
But a diy'er may have higher expectations than me.
Then be sadly disappointed. #justsayin :)
Bond
528
Highland
I said "you would expect it to be fit for purpose" . I don't think Norton is aiming this blade at the tiling professional, it's a multi purpose blade. I have used expensive diamond blades for cutting copper pipes,metal trim etc, ( because of convenience) no doubt to the detriment of the blade. Therefore a blade like this l think has a place in the toolbox " along side all the others". Just my take on it. :)
Reply to 1mm cut off disc other uses in the Tiling Tools area at TilersForums.com
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Better apolgise for not being an active member for a couple of years. As per title, looking for...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Tiling Tool Popular Threads
Albert
Gateshead NE8, UK
What member type are you?
  1. Professional Wall and Floor Tiler
Business Name
Gateshead Ceramics
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
