1st timer
well im not a tiler but certainly no diy'er
i have my own joinery business been going 12 years so far,
when i bought my house i paid a good tiler to do my kitchen/bathroom, the time has come for another tiling job but this time i am seriously thinking about doing this one my self
im looking at tiling my living room/dining room with the view to continue into the kitchen later on once i get warrent to knock down a supporting wall,
the area im planing is 3610mm plaster to plaster with clearance under the grounds where skirting was removed for any adjusting, i plan on using 600mmx600mm porcelain tiles so thats 6 tiles wide with fingers crossed no cutting on the width of the room,
the length is 8300mm between plaster,
its going on a wood floor which i have sheeted and screwed every 150mm or less using just short of 2000 screws, long ones into the joists and shorter ones into the original boards,
i have set out a string line across the door just so i know the tiles will be ok at the threshold and have got a second line checking for square, im planning on starting from the back wall left side so i can get out the only exit, think if i can lay a row each night 6 rows souldnt be to bad, i know about starting from centre of the room by strining lines but think i should start where i have said, i will be dry laying and also chalk lining every row taking all sizes from the string along my threshold, plan on useing bar single part flexible adhesive as well, any tips or pointer would be great, although im not comitted to doing this myself yet just got it planned and thought out just in case, as you will see in the photo im stopping a good 2ft short of the wall thats going to be knocked down later so that i dont damage anything taking it down,
heres how it looks so far,
