Discuss 2 bathrooms - floorboards in the Bathroom Tiling Advice area at TilersForums.com.
F
FreeD
Hi there
Wondered what u guys would price for this job.
bathroom 1
7.4 m2 onto old floorboards...these need to be secured to the joists...maybe a couple replaced...in a bad way. Then room needs to be overboarded. Then tiled with pocelain 300 x 300 cuts need to be made around toilet, bday, bath, basin base.
bathroom 2
1.94 m2 same as above but only needs cuts round basin base.
F
FreeD
Hi.
Just worked this out...i'll be overboarding with hardibacker 6mm, customer wants diamond pattern in both bathrooms. Some tricky cutting.
Bathroom + Shower
Secure Floorboards.
Overboard Floorboards with Hardibacker 6mm cement based water resistant backerboards.
Fix tiles, diamond set layout with flexible adhesive.
Grout tiles.
Supply and Fix threshold strips at transition between tile and carpet.
Materials: 275
Labour: 480
Thinking its going to take me 4 days for both rooms as its first time diamond, and theres some tricky cutting...feel like i should be charging 580 labour but think i'll lose the work if i go that high...what u reckon?
F
FreeD
yep was originally porcelain...now different tile 300 x 300 ceramic.
Surely the day does not include securing floorboards and overboarding?
I guess its the diamond pattern that has made me think about increasing the quote...its hard cause i'm still learning, and want to do a quality job, but again i know the customer and don't want her to feel like i'm ripping her off...i think 300 labour is to little as i've seen the job...480 maybe a little to high though.
Reply to 2 bathrooms - floorboards in the Bathroom Tiling Advice area at TilersForums.com
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Unsolved
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
