I
itidiot
Hi All,
Been absorbing all you advice and tips on here.... top work guys!
I am currently tiling my bathroom in 600 x 300 porcelain floor to ceiling and have two questions which affect two different walls
Question 1 - I have sink which is 600 wide and I have already stuck the tile behind it (got too excited!!), its stuck so it lined up with the sink. However if I continue the brick bond pattern along I will have a 1 cm slither on a couple of course's. Would it look a mess if I offset the brick bond pattern to a ratio of 55:45... ie. off set the the next course centre line by 1inch? (I have already done one wall so i couldn't carry on this offset)
Question 2 - On the wall beind the bath I have marked a centre line down the wall but it will leave tiny triangles if i work to this where wall meets ceiling. Can i move the centre aline over to the left so I wony have these tiny triangles. Will it look out align and worse than having tiny triangles?
Would appreciate your opinions as you seen all the problems before.... ;-)
p.s. LOVING MY LASER LEVEL ..... So glad i listed to that tip!!!
