Discuss 20mm Thick external porcelain, best adhesives and expansion joints in the Tile Adhesive and Grout Advice area at TilersForums.com.
I also plan to brace the expansion joints in the screed with a strip of uncoupling membrane to act as a movement joint, thoughts ?
TIA
Sorry if I’m misreading this,
Do you mean you’re covering the expansion joints with a strip of matting?
As Julian says above, if there are joints in the screed, then there should be the same joint in the tiles.
Expansion joints should not be covered.
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Kerakoll have a full system for external patios, I have attached a data sheet. This system makes expansion joints very easy. Basically lay a traditional sharp sand and cement screed over your sub base and include expansion joints, apply Kerakoll Green Pro decoupling, but do not cover expansion, tile but grout nearest joint to expansion with Silicon. All items available from TileFix;
Call Karl at Kerakoll for more info 07799 70‬3378
  • System_C8_update.pdf
I get that expansion joints should be followed through the screed to the tile.
But I cannot find a 20mm deep stainless steel external grade movement joint.
Does anyone know where I could purchase one?
Dural do stainless steel movement joints up to 50mm deep. Give them a call to find a local stockist.
Reply to 20mm Thick external porcelain, best adhesives and expansion joints in the Tile Adhesive and Grout Advice area at TilersForums.com
gamer1
I plan to lay a circa 8m x 4m patio using a concrete slab and fixing with tile adhesive. The...
6K
23K
Deleted member 57709
Tile Adhesive Trending Topics
Essex
Business Name
Thames Estuary Tiling Ltd
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
