Discuss 20x50 Decor Tiles Splasback in the Canada Tile Advice area at TilersForums.com.
paul3944
Hi All,
Just been to look at kitchen splashback ( L shape worktop with window cill) where the customer wants something simlar to the following fixing.
Original Style Tileworks Montblanc Decor Pearl Tile 20x50cm | Tiles Ahead - https://www.tilesahead.co.uk/PBSCProduct.asp?ItmID=21729339
Would it be wise to fix in brick bond so the repeats in the tile are not as obvious?
The inside corner would look best with the pattern wrapped in the corner, however I can see a problem where i will have a vertical cut thru the centre of the pattern to accomodate the window sill. What would be the best method to overcome this?
Sorry if it all sounds a bit vague.
Thanks in advance
Paul
Reply to 20x50 Decor Tiles Splasback in the Canada Tile Advice area at TilersForums.com
Hi all, I've had a go at tiling our cloakroom loo and its going ok, (I am extremely slow, it...
Hi everyone, Im after advice tilling my kitchen walls behind hob, sink and under wall cabinets...
Hi, Running a small bathroom job for a customer. Customer really wants to use a particular...
10K
    • Dislike
Hi all, new to this forum so thank you in advance for reading my post. I'll try to be short and...
Jacko
Currently tiling our new ensuite - I'm not a pro, this is my first large tiling project. Using...
9K
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
