Discuss 22mm Ply or 22mm chipboard? in the British & UK Tiling Forum area at TilersForums.com.
U
ukracer
Got some answers already from previous post and ended up ripping up ensuite floor that was 18mm chipboard due to bounce and creaks.
Going to strenghthen joists tommorow and put down new floor.
Which would be better 22mm ply or 22mm chipboard panels ?
Once down does it need anything doing to it before i tile with Bal flexi?
Also was mentioned to use acrylic sealant ,think for the new bare plasterboard before tiling is this correct? And do you have any recommended products?
DERBER
Going to strenghthen joists tommorow and put down new floor. 1
Which would be better 22mm ply or 22mm chipboard panels ? 2
Once down does it need anything doing to it before i tile with Bal flexi? 3
1.. good idea
2.. 18mm wbp ply screwed at least every 300mm
3.. Prime under and on the edges of the ply
4.. sbr primer or what your dealer sells. NOT PVA. Bal White Star is self priming. walls only.. But then again i always prime anyway...
Reply to 22mm Ply or 22mm chipboard? in the British & UK Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Hi all, I have a small WC about 2m2. I realise now, that I should have taken up the Chipboard...
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
