Discuss 250 x 400 - tubbed or powder in the UK Tiling Forum area at TilersForums.com.
Gazzer
Taken from Palce website PDF
"When fixing porcelain tiles the drying time of the adhesive will be significantly extended therefore grouting should be
delayed until the adhesive is fully dry, additionally any porcelain tiles of size 300mm x 300mm or greater should ideally be fixed using a
cement based adhesive. Additionally, all types of large format ceramic tile, i.e. those with dimensions of 300mm x 400mm or more, will also
significantly prolong the drying time of this adhesive and a cement based alternative is strongly recommended in such circumstances."
Bhoystris
Just an add on to this thread. I am going to be starting a job soon involving 300 x 600 ceramic tiles onto plasterboard. Never tiled a wall with this size before but will be using a powder based adhesive. My local supplier stocks bal adhesives. They have a C1 tile powder adhesive called CTF3, which i am thinking will do the job after the plasterboard is primed with acrylic primer. Has anyone used this type of adhesive before, good? bad? or other recommendations?
Reply to 250 x 400 - tubbed or powder in the UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
    • Winner
    • Informative
So as a couple of you may be aware, @Simon Dale his daughter Katrina, and myself are on a...
11K
L
