Discuss 25mm plywood in the UK Tiling Forum area at TilersForums.com.
On one
If the ply was treated in SPR before fitting ie: underside & edges, I don't see any problems in using a SPF. If ply has not been primed before fitting, I'd use a 2 part
Nice reminder! Ply has been cut but has not been fitted as sparkys are running cables around/under at the minute.
widler
1,328
England
never use 6mm ply you might as well put cardboard down 6mm is just not thick enough
if this was aimed at me brian,read it again,i said use a thinner ply(he said 25mm,i was thinking a tad thinner if the height was a problem,or keep 25mm,then hardi if not a problem with height)then 6mm or 12mm HARDIEBACKER,which is not ply :smilewinkgrin:
On one
could you not use a thinner ply then 6mm or 12mm hardiebacker ?
Fraid not. Builder already has cut and loose fitted 25mm ply. He choose 25mm ply so that the levels matched an adjoining utility room tiled floor that he wanted me to overtile. But I have condemned the utility room tiled floor because you can lift the tiles up with your fingers! (tiles layed on a 25mm very weak mix of sand and cement)
If he had contacted me sooner it could have been 18mm ply,12mm Hardi and then an S1 adh
Reply to 25mm plywood in the UK Tiling Forum area at TilersForums.com
Bit of an intro - I'm a competent DIYer and have been refurbing the bathroom on and off for the...
6K
L
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
25mm plywood
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
