csne2x
I've been tackling our bathroom, this is how it was initially. Only 4 years old but the Mrs decided she wanted a new shower and tiling so I set about getting it done.
I am at present 50% of the way around the room with the tiling.
The tiles are 900 x 315 from porcelanosa and due to there size and the lack of size in the bathroom it's proving tough getting the setting out done.
Can I have some opinions on my setting out at present?
And in the first two pictured the best way to set out the bare wall that goes around an internal corner. I was going to butt the tiles leaving a small gap and me fill with silicone. But then I wasn't sure if I should mitre around the corner
I have a few options.
Start in the middle which leaves small cuts at the 90 degree corner and also a small cut before it goes around the internal.
Start the tile at the door and cut it around the corner leaving quite a big cut at the window
Start a full tile to the left of the internal which leaves a decent sized cut at the window and then cut to fill the space at the door.
I hope all of the above makes sense, it's hard to get over in words.
