E
eBay
【Arm Hand Tool Unique Steel Process】 : Steel material of the Height regulator has undergone a secondary quenching process. 【High Quality Solid Steel Material】 :Upgraded lifting tools, thickened solid steel base and lifting rod, the lifting capacity is stronger, thickened stainless steel wave high-strength spring, longer service life.The widening design of the handle increases the force-bearing area and is more comfortable to use.
Continue reading...
