E
eBay
Features:-Made of aluminum, it is wear-resistant, chip-resistant, and corrosion-resistant, ensuring long-lasting use.-The handle is ergonomically designed and has a non-slip texture to ensure a firm grip.-The enlarged and thickened rubber suction cups can prevent damage to the surface.-It has a strong load capacity, a single piece can bear up to 100 kg horizontally and 80 kg vertically. (Note: if the use environment or method is incorrect, the maximum suction may not be achieved.)-With quick release buttons, it is easy to operate and improve work efficiency.-Suitable for carrying glass, ceramics, wood, plastics, metals, etc.Note:1. The suction cup should be attached to a clean, dry, non-porous, flat surface;2. The suction cup should be clean and dry before u.
Continue reading...
