Discuss 3 - 4 mm dip in floor in the UK Tiling Forum area at TilersForums.com.
Aspesim
Hi guys
I’m going to install 6mm Hardie-Backer Board over 18mm ply, however there seems to be a dip across the 2.0m room 3/4mm at is lowest point feathering off as it moves out from the middle.
As stated the floor is ply (two sheets with a 3mm gap between them) would I need to use SLC or would Bal addy be sufficient to level the floor?
Would I need to level the floor before the 6mm HBB’s?
As usual thanks for you help and advise.
Aspesim
Aspesim
Thanks Guys
Ok it seems 2 & 2?
Would I have to treat the ply before laying the SLC (as most of it is water)? Any make of SLC? What would I use between the 3mm gap in the ply?
Addy seems easier but what is best ?
Any more for advise on SLC or Addy Welcomed plus any other advise is always welcome here!
Thanks Guys
Aspesim
Reply to 3 - 4 mm dip in floor in the UK Tiling Forum area at TilersForums.com
Hi, Would you use Durabase matting over Hardie 6mm floor? Im not 100% happy with the ply floor...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hello all, I am planning on tiling my bathroom floor, I removed the old tiles myself which were...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
