Guest viewing is limited
Discuss 3 light chandelier issue, 2 bulbs are dim but if I install the 3rd, the other 2 go off. Electrical Advice in the Electrical Advice area at TilersForums.com.
3 light chandelier issue, 2 bulbs are dim but if I install the 3rd, the other 2 go off. Discussion Thread3 light chandelier issue, 2 bulbs are dim but if I install the 3rd, the other 2 go off. Electrical Advice
I had this issue with the old wiring on the chandelier along with light flickering, so I rewired the chandelier with new sockets and 2ft. leads into the main house wiring as it had been before. Same issue was happening, so I replaced the dimmer switch, same issue happening. I bought all new dimmable light bulbs as a last resort but alas, same issue, as soon as I install the third bulb the other 2 go off. Any ideas? Can this be caused by the house wiring itself? Thank you so much for reading, this has me completely baffled. :O)
3 light chandelier issue, 2 bulbs are dim but if I install the 3rd, the other 2 go off. for the original thread on Electricians Forums
Reply to 3 light chandelier issue, 2 bulbs are dim but if I install the 3rd, the other 2 go off. Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
