F
Flintstone
I thought I'd share this project, quite a lot went into this and I think it turned out great. The floor was a bit of a mess so there was some leveling prior to fitting the insulation and underfloor heating.
This system is the new pro warm system which uses the dural cifh carrier mat and there 6mm cable, spaced to suit your needs, this one was 185w.
This was the perfect job for Kerakol fugalite bio parquet epoxy with there being several dogs in the house. First time using this epoxy and I found it fairly straight forward and the finish is far superior to regular cement based grout.
The forum is telling me some images are too large for some reason.
