Discuss 4mm thick porcelain in the British & UK Tiling Forum area at TilersForums.com.
peckers
Seen them in tilemarket/tileflair they have the 600x300ish ones there in 4 colours if i remember rightly, they are strait and flat, they do state for walls only and they come with matching floor tiles at 10-12mm thick Havent had the call to fix them yet but i like the idea of them, would like to see the 1200mm ones to see if they are flat too...
I worked with them many times, these tiles called ''Kerlite''
They are 3mm thick, sizes vary from 400 x 1000mm, 1000mm x 3000mm, 1000 x 1000mm and so on... they really easy to brake, but when you install them they hard as normal porcelain, layed on the floor too no problems at all, I'll post few picks how it looks
Reply to 4mm thick porcelain in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
4mm thick porcelain
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
