Discuss 5.6mm porcelain sheets in the Australia Tiling Forum area at TilersForums.com.
Hi, wondering if anyone has used these 3000x1200x5.6mm porcelain sheets, I bought the rubi slim system cutter last week to tackle these but I managed to get one cut 3000x370mm but then lost the next 3 sheets as they just split when I tried to break them, I got the two ends started with the hand snappers supplied but as soon as I put pressure on to complete the break they split in half, I also tried angle grinding one but this split as well, any advice would be appreciated,
john,
Have'nt fixed those but have the 1200x600x .48mm and do find that care has to taken when snapping.
The one you describe with the Rubi cutter needs running over a couple times viewing the utube vid.
hi whitebeam,
thanks for your reply, I've always been of the understanding that you should only score once don't tell me I've been doing it wrong all these years ha ha,
john,
White Room
hi whitebeam,
john,
Your right about one score with the Rubi
Even Sigma do the same[video=youtube_share;015nrI06ngg]http://youtu.be/015nrI06ngg[/video]
Rizzle from the Portizzle
well to cut these you need to put them on a bench like in that vid but thats a big bench to get on site next when cutting you have to keep the speed and presure constant .stopping while cutting will end up with a point loading and can cause the tile to run off .i have cut
loads of 5.5mm with no problems you can always come down to south london show you a few pointers
Reply to 5.6mm porcelain sheets in the Australia Tiling Forum area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
I am planning to tile bathroom with large porcelain tiles 1200x600 over water-resistant backer...
Hi I have a bit of an issue. Had some tiles laid down, and the builder put Antinox Handy...
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
hendon nw london
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
