Discuss 600x300mm wall tiles - suitable adhesive? in the UK Tiling Forum area at TilersForums.com.
Bill
Can anyone please advise on a suitable adhesive for fixing 600x300x10mm thick porcelain tiles (CTD Gemini mineral quartz range) to moisture resistant (green) plasterboard walls in a bathroom; would BAL WhiteStar be suitable and should I prime the moisturecheck plasterboard first with something?
I'm also a bit worried about the weight; the tiles are 10mm thick porcelain - would these be OK to fix to plasterboard? Catalogue says they're suitable for floors and walls.
Help appreciated.
JCT
you would use fastset on walls if you need to grout the same day..it has ite benefits..hope you understand.:thumbsup:
Aye. Forgot to mention thats the only time I use it:thumbsup:
I actually did a full 25m2 bathroom using keraquick recently. 600x300mm travertine. Only used it as I couldn't buy maxi locally at the time. Never again:mad2:
The guy was talking about using white star tho so I assumed he wasn't planning on groutin the same day.
JCT
John...where do you buy the kerraflex maxi?
Tile it all. They usually need to order it in so always allow time for that. Thats how I got caught out. Shop assistant told me they stocked it witch wasn't the case. That place in Kirky could probably order it inn, they use maipei, am sure?
You can also buy it from CTD and Cosmos but thats a bit of a treck for a local job. Porelanosa also have their own version which is cheaper
Reply to 600x300mm wall tiles - suitable adhesive? in the UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
