Discuss 6mm Marmox on Floor in Prep for UFH in the British & UK Tiling Forum area at TilersForums.com.
siremastimus
Hi, have remove my floorboards and replaced with 18mm WBP ply and now need to lay down some 6mm marmox boards in preperation for under floor heating in bathroom. The general opinion seems to be to screw to ply wood using marmox washers and also lay on a bed of adhesive. Silly question but should I lay the marmox down with the adhesive and then once dry, screw down or screw down before adhesive has set? Thanks
Reply to 6mm Marmox on Floor in Prep for UFH in the British & UK Tiling Forum area at TilersForums.com
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
gamer1
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
