Discuss 900x150 Porcelain Planks Spacer Size in the Canada Tile Advice area at TilersForums.com.
ProPrecisionTiling
Hello All,
Looking for a little bit of advice for an upcoming job...
900x150 porca planks - what spacer size would you use? 3mm, 5mm or other? Customer wanted them laid in half brick bond but have advised should go for 3/4 running bond to help avoid bowwing/lippage issues. Don't see too many 900's around here, so what spacer size would you go for?
Cheers
ProPrecisionTiling
Not necessarily it’s 3mm for floor by British standards I think ( I’m sure someone will correct me ).
Plus if the tile is bevelled edge using 2mm will give an appearance of 3mm once grouted
Yeah 3mm is BS standard and always followed that. But in your experience 2mm is more than okay as well? I see the benefit in using 2mm. I will make a decision when I get my hands on the tiles
ProPrecisionTiling
Thanks for the replies everyone looks like a toss-up between 2 or 3mm then.
Probably go 2mm as it appears the British Standards are a bit outdated and a lot of you are disregarding them anyway! Ha. My only worry was they were there for a reason but it seems pros are having no issues with 2mm (or even smaller)
Reply to 900x150 Porcelain Planks Spacer Size in the Canada Tile Advice area at TilersForums.com
Evening all, I've got a job coming up soon in a bathroom, wall to ceiling around the bath then...
Hello - we're in the process of choosing tiles for our bathroom and I'd really appreciate some...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
