Discuss Acceptable tiling or not? in the Canada Tile Advice area at TilersForums.com.
Michelle M
I've just got home from work and this is the tiling in my en-suite so far. Is this acceptable or not? I've included 5 photos and I'm having my ensuite tiled throughout with the same tile:theres a photo where the floor meets the walls and the tiles do not line up. Chips in the tiles, Where the window frame there is the silver edging strip used and this is not flush with the tile i.e the tile sticks out and looks raised, a tile which has been cut down the edge which looks like it has a serated edge.
I'd appreciate your views as to whether you'd be happy with this level of work.
Michelle
Michelle M
Hi Pete
Not spoken to the tiler yet as I didn't get home before he had gone. However I shall speak to him tomorrow morning. I just wasn't sure if I was within my rights to complain about it.
Here's a picture of the other side of the room so you can see that the tiles match up on the other side.
How would he go about fixing this now tho?
Michelle
Michelle M
Am I out of order asking them to do this? What about the cost of the tiles? Should I expect them to replace them as they messed up in the first place?
I wouldn't mind but I've paid a lot of money for this. The tiles were from porcelanosa and the fitter is charging me £** sqm.
Thank you everyone for your posts. I appreciate the comments as I know its not just me being fussy now.
Michelle
John Benton
1,138
Leeds
If the tiler had set the room out in the first place then he would have known where all the joints would have been before he had even stuck a tile to the wall or floor. Was the tiler recommended by Porcelanosa Michelle?
johnryan
as i and a couple of others mentioned before you'd need to take up the floor to fix it, but even then you'd have cuts by the shower and door walls that were out of parallel. i think bri mentioned that strictly speaking the wall tiles that are out of line would have to come off and be redone. do you know if he used tubbed adhesive for the walls. if so it's not suitable for this application, but on the bright side if he did the tiles could be taken off and used again.
Michelle M
No not paid yet. Its 40sq as well so will be a lot. No the tiler was not recommeded by Porcelanosa. I've had a complete bathroom makerover by Wickes. So they have supplied them.
It's about an inch out as well. The room is perfectly square but he's not measured correctly. To be honest I've had the wall built on the right by him to make this ensuite so if its wasn't square it would be his fault as well. But I've measured the distance from wall to wall both ways and its completely perfect.
Would you not pay for any of the tiling if he refuses to not fix the problem?
Here's a close up: photo (6).JPG
Michelle
Reply to Acceptable tiling or not? in the Canada Tile Advice area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
Hi, 1st time tiling, decided our ensuite would benefit from being a wetroom. Quick question, any...
Hi there I’m new to Tile Forum and joined to get professional opinions because I really need...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
