Discuss Adhesive advice for 60x30 porcelain wall and floor tiles in the Best Floor Tiles area at TilersForums.com.
Y
yorkslad
Hi,
I am going to tile the bathroom walls and floors in 60x30 glazed porcelain. The walls are a mix of p/board (will prime first) and aqua panel. The floor is wooden floor with tile backer boards and underfloor heating.
I was thinking of using keraflex maxi for both the walls and floors - would this be OK? Or, is there a better flexible adhesive I can use on the floor that will set quicker?
Cheers
Rob
Reply to Adhesive advice for 60x30 porcelain wall and floor tiles in the Best Floor Tiles area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
