Discuss Adhesive etc advice in the UK Tiling Forum area at TilersForums.com.
Q
QWERTYY
Hi,
I would appreciate a bit of advice from you learned fellows.
I have had our bathroom professionally tiled a couple of months ago and I have a few very nice marble floor tiles left over (approx 600mm x 400mm x 15mm)
It is only a small job so I thought I would try my hand and use them to form a splashback above worktop in the utility room.
The wall are brick/plaster and freshly skimmed.
Do I need to prime wall?
Seal Tiles before applying?
Is there a particular adhesive for marble?
regards
James
Rich
How high will you be tiling? Plaster doesnt not hold a great deal of weight and is often not strong enough to hold the weight of marble but if you are only going one tile high then I wouldn't worry about it to much. The wall will need priming with an acrylic primer and you will need an cement based (powder) adhesive that is suitable for marble as well as a suitable grout. Have a look through the link below and see if there is a Tile Giant near you, they should be able to sort you out with everything you need.
Mapei: Tile Giant Store Finder...
Reply to Adhesive etc advice in the UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Adhesive etc advice
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
