BLOWKY
The time has come where I can't put off the tiling any longer, She who must be obeyed has spoken!
Floor is 22mm chipboard with 6mm hardi glued and screwed with UFL covered in flexible SLC, all feels pretty solid even with our combined weight of 30+ stone jumping up and down on it, recomendations on the adhesive please for 60 x 40 honed limestone.
Walls are a combination on blown concrete block, concrete block and stud, all have been covered in either 6mm or 12mm hardi glued and screwed, again what adhesive would you use for 60 x 40 polished limestone.
Another question on the fitting, my plan is to mark the wall one tile high, batten and then tile everything above the batten, tile the floor completly and then fit the bottom row of wall tiles all round, there is a lot of cutting on this row as part of the floor is split level and going round the shower tray etc, how does this sound? I want to do it that way to protect the floor from damage.
The en suite will have a lot of Roper Rhodes furnitue in it, is the correct method to tile behind or tile up to units?
Re the adhesive, I work slowly so nothing that will go off quickly.
Last thing, what size notch on the trowel?
Oh and is there an out of work Tiler in Hereford that works for P nuts to save me the headache of all the above?
Thanks to anyone that replies
Regards
Blowky.
Regards
Blowky.
