ruffryder
Hi fellow tillers!
I’m not a DIYer, more an individual who has begun research and supply of materials to our fitter to renovate our bathroom (conventional bath tub, toilet, sink and shower tray ie no part of it is a wet room). I’m hoping you knowledgeable guys out there can assist with my queries and approve or suggest alternative solutions.
Our fitter wants to properly screw down the tongue and groove floorboards to the joists before applying Ardex X 7001 adhesive (is flexible apparently) to bond the Marmox 12.5mm insulation boards on to it (I don’t like ply). He may lay a self levelling compound, then lay the Warmup loose undertile wire (is this a good brand amongst the 10 or so other brands out there?) and slap down some more Ardex X 7001 addy and bond 10mm honed and calibrated slate to it. The slate tiles will then be grouted with Ardex-Flex FS grout, cleaned and two layers of Lithofin Stain Stop Sealer will be applied.
He prefers to seal as stated above rather than to seal the slate before and after the grout has been applied. Does this matter? Is this a minor issue I am worrying about?
I am struggling to opt for a wall adhesive for the 60x30cm ceramic tiles. One wall is new stud wall with plasterboard and another will have more of the 12.5mm Marmox insulation boards. The other walls will have the new ceramic tiles laid straight over the old ceramic ones (cardboard grid based stud wall behind). Is there a decent powder based adhesive which can be applied to all of these surfaces? Doesn’t have to be by Ardex! Someone has suggested Ardex D30 addy but that’s a ready made paste and am therefore reluctant to use even if it is made by Ardex. The same Ardex-Flex FS grout will be used for the ceramic tiles, any issue here?
Is it also necessary for me to purchase Arditex NA wet and dry stuff to hide the undertile heating cables?
Lastly, a non-tiling question, our fitter wants to mount the extractor fan to the ceiling and connect the 4” flexible pipe into like an “n” shape so that it exits through the soffit outside. Problem is I want to attach a 6” fan due to the size of the bathroom (and it’s a quiet fan too!) but the 4” flexible pipe is going to restrict airflow isn’t it and probably labour the motor? Are rectangular flexible pipes available by any chance?!
I would appreciate your thoughts and help on the above.
Thanks in advance.
Thanks in advance.
