Discuss Adhesive thickness and grout width?? in the British & UK Tiling Forum area at TilersForums.com.
E
ellexesse
Hi
As a beginner, can you recommend the adhesive thickness and grout line for a 20x25cm ceramic tile? I'm not sure of its depth and can't check right now but they are not thick! Can check tomorrow if needed.
Also, would a tubbed mix be suitable or should I get powdered? (I am in France and went to get powdered but couldn't see one that seemed suitable for shower walls).
grumpygrouter
Grout joint thickness is a personal thing although there are recommended minimums depending on what you are tiling. BS minimum is 2mm for walls and 3mm for floors. I try and always discuss joint thickness with my customers by giving various examples with the chosen tiles by laying them out with different joints widths. The choice of grout colour can have a bearing too as if a contrasting colour to the tile is selected a wider joint might be more appealing...if you get my drift??
Reply to Adhesive thickness and grout width?? in the British & UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
