cityone
Hi lads, this is following on from my post the other night where i have decided to use hardie cement boards instead of plywood due to the poor quality of ply now available. Anyway, i would like to use the 6mm board (because of raising height issues) for floor overlays but BAL (my prefered choice) only recommend single part fastflex which is 3 times the price of my usual floor adhesive, (bal spf) if i used the 12mm board i would have no problem with spf, so for 6mm backer board what floor adhesive do you recommend???? also, can i get away with just screwing the backer board to the substate or do i have to use adhesive as well as screws??? once again thanks in advance for any feed back!!!!
