Discuss advice fixing natural stone tiles in the UK Tiling Forum area at TilersForums.com.
boxhead
im after some advice lads.on short notice ive been asked by a builder to fix some large natural stone tiles on a wall. this is my first stone job.the tiles are 12mm thick and 400x200. they are quite heavy, some will be upside down under a shelf. 1; do you recommend a 6mm or 10mm trowel. 2; they are dusty, should i back skim them. 3; they are almost white,do i seal them, if so before grouting them and after.and finaly 4; what size grout spacer would you advise for the job.would appriciate the help as i start these in the morning.ta:huh2:
Time's Ran Out
1) Solid bed fix 8mm trowel .
2) Flat back on sponge wiped tile.
3) Seal them before you touch them! Seal them again before grouting - if clean and dry. Seal again if required after grouting and only if clean.
4) IMO 3mm.
Check what the wall surface is before fixing - weight!
Use a powdered fast set WHITE adhesive.
Timeless John.
djr tiling
i agree with john on most points i think the spacer size comes down to a couple of things
do the tiles have a rectified edge or are they tumbled edge ?
if rectified i would use 2 or 3 mm spacers
also ask the customer what size joint they want as they may have seen them fitted somewhere and they already have a look they are looking for
i would use a slower setting adhesive if you haven't done stone before but definitely a powdered one
and definitely check what surface you are fitting on there is a lot of weight there
oh and good luck and take your time :thumbsup:
Time's Ran Out
As djr tiling, if they have a bullnose on the edges they are possibly tumbled.
In this case a smaller joint 2mm might be aesthetically more appealing.
The advantage of fast set adhesive is with the larger heavier tiles there is limited back suction and you can fix a smoother finished face of the tiles.
If you can tile and mix just enough adhesive to use in 10/15min it is my choice.:thumbsup:
Timeless John.
NO seal tiles BEFORE you look at them.
Reply to advice fixing natural stone tiles in the UK Tiling Forum area at TilersForums.com
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
