Discuss Advice needed guys - Uncalibrated slate floor tiles in the Best Floor Tiles area at TilersForums.com.
GDR111
Hi folks,
I am a newbie to the forum, so bear with me.:stupid:
I have just bought a new built home and what I am looking for is really advice / opinions on uncalibrated floor tiles (slate).
I am planning on using slate floor tiles to the hall, kitchen and utility areas (approx 45m2). I have got quotes from a few different companies for the tiles but the best I have found by far is one through ebay offering £11/m2. The slate tiles are 300x300 but their thickness is not calibrated (8-12mm). I have found this with alot of the quotes I have been getting so really what i am looking for is opinions on this. Is it this as big a curse as I think it might be to fit these, or should I just avoid them and run for the hills (just stay with a uniform thickness tile)?
I would like to try and have a go at fitting the final tile myself but as I work 80+hrs a week in a design office I might not be able to get the time.
Any advice would be greatly appreciated.
Cheers
Turkish
If not experienced i would avoid laying these yourself, if you do though you need to grade the tiles by thickness and use the thicker ones in the heavier traffic areas and the thinner ones around the edges. Ensure the substrate is flat and if sloping start at the high end adding more adhesive under the thinner tiles to ensure the tiles end up level. Slate will need sealing too and there are plenty of posts on here relating to that.
Hope this helps mate!
Turkish:thumbsup:
ps: You can get calibrated slate but it`s more expensive, might be an easier option, oh and you will need to include expansion joints at every 8 - 10 linear metres either by using a preformed expansion strip or just using Silicon
Reply to Advice needed guys - Uncalibrated slate floor tiles in the Best Floor Tiles area at TilersForums.com
DIY Tiling; Advice for DIY Tilers So long story short, I have just purchased my first house and...
Best Floor Tiles
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
