TinyFlat
Hi
I have a patio with a concrete base which has depressions in some areas. The highest level of the concrete seems to be around the edges where the concrete meets the walls (patio is enclosed by 4 walls) and it seems to have sunk in the middle over the years.
How would you even this up before laying limestone flags? I also have two doors (one from a bedroom and the other from a living room) that open out onto the patio so i am conscious I need to stay below the threshold to avoid any damp problems and both doors open outwards (it's a basement flat too).
I've been told a levelling compound needs to go on top of the concrete. Someone else (limetsone supplier) said use the depth of the mortar to level . I am really confused and would value some professional opinions from here as to how you would do. The slabs i want to use come in 22mm and 17 mm thickness.
Many thanks
Many thanks
