Advice needed please Discussion ThreadAdvice needed please Electrical Advice
Hello, what would I need for the following...
A 40 meter cable run through fire partition walls, into a large plasterboard void to supply a switched fuse spur that will be used as power for a LED advertisement screen, unfortunately there's no forthcoming info on wattage.
what cable size would you recommend? Why?
what breaker type would you recommend? Why?
Thank you for your input/advice
Advice needed please for the original thread on Electricians Forums
