Discuss Advice needed please guys in the UK Tiling Forum area at TilersForums.com.
jay
more a question than advice but if the chip board were removed could you use hardibacker type board instead or will it not support loads in that way??? just that I got to redo my bathroom soon and that is what would be easiest for me to do
Best bet is to remove chipboard replace with wp ply then overlay with 6mm c/s screwed and glued with staggered joints
even if you remove and replace with say 19 mm c/s the joins can cause an issue and need special treatment
hope this helps
Reply to Advice needed please guys in the UK Tiling Forum area at TilersForums.com
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
Hello All, I would just like to start off by saying that I've been in the construction industry...
TF Group Please Join
