gmt1981
Hi guys,
After spending time carefully prepping a small ensuite with backer board, a local tiler (pro - not just a jack of all trades) has done a good job on the walls but has messed up the floor.
The narrow walls are plumb straight, but the back wall is not. For some reason the tiler has used the back wall as a base so the tiles are crooked, with narrowing and widening cuts on both sides as per the photo.
Without coming round to check, the tiler knew what I was talking about and offered to sort it. It seems he realised it was going off in one direction but just carried on as the adhesive had started to set. I was in at the time and had spare tiles so wish he had just stopped and checked with me to see if I was happy.
Anyway, he's coming round on Monday as this is the only day he's available all month. I suspect he will try to do the job in one day but I'm concerned that the backer board will be destroyed when trying to remove the tiles and adhesive. Does anyone have any experience of doing this and tips.
I used no more ply which was glued and screwed to the floorboards.
Is it reasonable to expect him to cover the cost of the replacement materials (ca. £70), as although I can be a perfectionist, I don't think I'm being fussy here?
Also, if the backer boards have to be replaced, how long after priming can the tiles be laid?
Many thanks
Graham
Many thanks
Graham
