Discuss Advice on limestone floor installation in the Canada Tile Advice area at TilersForums.com.
Pete.c
Hi, I am about to start laying a limestone floor, approx area of 80sq mtr. The stone is Sinai pearl antique 600x600 from mrs stone.
It will be layed on a larfarge gyvlon screed 60mm thick with wet ufh, this was poured 7 weeks ago, the heating was commissioned 3weeks ago and gradually bought up to full operating temp, then slowly turned down.
Floor has been sanded to remove laitances.
I was told to seal the floor with Ball p121 sealant, two coats. Adhesive is Gfix Csa flexible white.
The tiles would cover four rooms.Would it be possible to tile right through the doorways without a break, this would mean a longest run of 12 mtrs or will i require expansion joints? If yes, what distance apart would they need to be?
There is 8mm expansion foam layed around all edges of the screed with a 25mm thermal barrier on ext. walls.
Sorry for the long first post, The largest area i have tiled before was 50sqm, but this is my first limestone floor on gyvlon ufh floor.
Cheers
Pete.c
Thanks for the quick replies, looks like ditra or similar is the popular choice.
Is this because of the gyvlon floor or the limestone, or combination of the two?
Would you still use ditra if it was a ceramic tile?
Would expansion in the doorways be enough? I will still have a run of 9mtrs by 7.5mtrs in the kitchen diner, its an L shaped room.
Sorry for all the questions, just wanna get this right, its a lot of limestone.
Cheers.
Ajax123
1,213
Lincolnshire
Natural stone should be uncoupled. 7 weeks at 60mm even with the heating in the weather conditions we've had recently might not be long enough so do a moisture check first. The natural drying time for this depth would be 12weeks (80 days) in good drying conditions? We have had poor drying conditions in the last few months.
If you must use an acrylic primer go for BAL or Ultra but in my experience epoxy is better with cement adhesive. I would be looking to use a gypsum compatible system to stick the mat down. A vinyl type adhesive might be a better option then your normal flexible adhesive on top. Joints in door hers holds are a must and these should also be in the screed. There should also be joints in the screed between heating zones and where hot meets cold. If these are missing that makes uncoupling even more critical as there is a much higher risk of the screed cracking.
Ajax123
1,213
Lincolnshire
Thanks Alan,
Would you still use a decoupling mat and expansion joints if it was a standard ceramic/porcelain tile on gyvlon with ufh?
cheers. pete
generally not unless the screed has become unsound for any reason e.g thermal cracking and such likes. It is only natural stone that is covered within the BS and this is due to it having natural fracture lines whch make it susceptible to cracking under thermal cycling.
With ordinary ceramics or porcs I woudl however recomend the use of a gypsum compatible adhesive rather than a portland cement based one.
Ajax123
1,213
Lincolnshire
Hmmm. So are you proposing not putting movement joints in the tile face? This would be a mistake. Bear in mind you are uncoupling the tiles so the tile face will move ostensibly independently from the screed. As for the adhesive I would recommend a discussion with schluter to see what their current recommendation is. If they will not make a recommendation the speak to f ball and co who supply vinyl adhesives. Not sure which one is most apt.
m3fitter
Its ooooh sooo technical these days ..lol.. used to be 3/4" ply screwed every 6", PVA, white grout, grey grout, eye joints... rapid set with pva to make it flexible ( or AD1 if you were posh ! ) tub mix for wall tiles, all of your tools used to fit in an old tub mix bucket with your TS40.... ha ha.. the good ol days..
Now TX1200, rectified 1000x330.. acrylic, dukka, ditra.. UFH ( used to be radiators !! ) i'm only 43 ! feels like a different trade to when i started 24 years ago.
Reply to Advice on limestone floor installation in the Canada Tile Advice area at TilersForums.com
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
We're quoting to rip up and replace a tiled floor with Limestone tiles. I'm looking for advice...
gamer1
After some advice please..... We have approx. 50sq m of Dijon limestone 600 x 90 x15mm and also...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
