Discuss Advice on tile trim on window sill in the British & UK Tiling Forum area at TilersForums.com.
Q
quantasm
Hello,
I'm just setting out the plan to tile my bathroom and would like some advice on these two things....
1. I will be tiling around the window sill and am considering using quadrant tile trim around the window. On the window sill I would lay the trim horizontally across the sill so that the back of the trim is stuck with adhesive to the top of the sill edge. The trim will overhang the sill edge slightly to be flush with the vertical wall tiles. My questions are, when cutting tiles for the vertical wall do I leave a grout line space between the tile edge and the plastic trim overhanging the sill? Does grout stick and create a seal on plastic trim? The basin is directly underneath the sill so any join needs to be splashproof and will be highly visible. An alternative would be just to overhang the sill tile without trim and grout but just wanted to know if the trim which creates a plastic barrier between the two tile edges cause a problem when grouting or sealing?
2. When entering the bathroom the far wall (the first one you see) has the window, window sill, basin and toilet. I can either centre the tiles based on the window sill or the full wall. I'm planning to centre on the window sill as it's the focus but that leaves the left corner with a cut tile of 220mm and the right corner with 90mm (based on 400mm tiles). If I evened the corners then the window sill will have uneven cuts at each side. My preference is to centre the window sill but would appreciate any advice on this?
Many Thanks
Q
Alan.P
Re Q1, I've done it both ways. I've sit the trim onto the tile and I've also left a grout line between, dependant on what has been asked for, either way will be fine as at worse your only going to get a splash of water.
Re Q2 is the basin centre of the window, if yes then I would do as you say, even if it weren't I would still probably go with what your proposing.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Definately centre t the window. How does the window wall work out if you adjust by half a tile? I.E rather than having a grout line centre have the centre line running through the centre of a fall tile. If that makes sense.
Going by what you posted that would proberbly leave 20mm in one corner and 290mm the other. The 20mm would then be an issue. However, i'd expect a 400mm square tile to be 9-12mm in thickness, plus you bed of adhesive would narrow this considerably leaving a couple of mm's in the corner, your Silicon bead should cover this, and it's advisable/good practie to leave a couple of mm's anyway and not cut your tile tight to the corners anyway.
Mike Mike
I agree, centre the window. Re trim, yes grout sticks to plastic trim. But have you considered mitring the tiles and not using a trim? If you have a wetsaw, or a mitre wiz and an angle grinder, you can practise a mitred cut and compare it to a couple of loose tiles and a tile trim to see which you like best.
Good luck!
charlie1
Hi quantasim, re issue 1, I don't know what your tiling skills are but believe me, unless you are an experienced tiler, you will have a maire trying to tackle tiling round a window, there are loads of things to consider but I will stick to the point. I would fit a slightly thicker trim (1mm thicker) and fit the trim back vertical so that the trim will slighly overhang and slightly cover the face of your tiles, hope u follow. This will hide any uneven cutts u might have.
Re issue 2: as above ,centre off the window, full tile or half tile, whichever looks best.
Good luck
Reply to Advice on tile trim on window sill in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
