Discuss Advice on which drill set? in the UK Tiling Forum area at TilersForums.com.
Julz77
Morning all
Just looking for some advice on which drill set to buy. Looking at the Rubi set on Tradetiler
Tradetiler Tile Rubi Wall Tile Drills
But wondered if its good quality, and also as I am just starting out (trying to keep costs down!) do i need the full set or are there particuler sizes that I would defo need, and just build on my collection!?
Any top tips on drilling thru ceramic's also muchos appreaciate!
Thanks guys!
Julz :smilewinkgrin:
Concrete guy
Hope the thread helped.
The sizes you'll need will depend on the kind of work you carry out.
6 & 8mm - General rawl plugs for light fixtures & fittings
10 & 12mm - Fisher bolts for basins & toilets
15, 22 & 28mm - Water Pipework
32 & 40mm - Waste Pipework
That's a pretty standard list and a good starting point. Just remember to up size each pipe bit to give some tolerance.
6,7 & 8mm are all correct plug sizes.
10mm & 12mm the same
15mm pipe = 18mm drill bit to give that bit of room
22mm pipe = 25mm drill bit
28mm pipe = 30 or 32mm drill bit
32mm waste = 35mm drill bit
40mm waste = 45mm drill bit
you could also add
50mm waste = 55mm drill bit
100mm extractor fan = 105mm or 110mm drill bit
soil pipe = 110mm, 115mm, 120mm, or 125mm depending on exactly what's required.
Reply to Advice on which drill set? in the UK Tiling Forum area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
After some advice please..... We have approx. 50sq m of Dijon limestone 600 x 90 x15mm and also...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
