Chris G
I have a 52m kitchen/diner/hall floor to tile in a couple of weeks (600x600) Its over electric UFH . Their sparky has already fitted insulation boards and warmup matting . I will be self levelling on top to encapsulate the cables . Is their a minimum mm height you have to go above the cables ? Should I use a fibre SLC?
My other concern is the need for any expansion joints. The kit/diner is 42m (6x7) and it split in half by original slab and extension . Now the UFh is down Iv no way of telling we're the 'fault line' is exactly if I need to fit expansion joint .
Would I get away with not having an exp joint ?
Any advice very much appreciated . Cheers
