Discuss Advice requiredpls in the Canada Tile Advice area at TilersForums.com.
John Benton
1,138
Leeds
Following a post a few months ago from a member of the public I have been out to remove the tiles from the wetroom tray due to the tiles not being fixed/grouted correctly, prior to them moving into the house.
Some of you may remember this was the wetroom tray originally
After removing the tiles
There has never been any leaking through the floor (which may surprise you). It does actually look as though it has been tanked correctly. It is an Impey tanking kit and drain.
What I now need to do is remove the addy in preparation to re-tile. My question is, not having removed addy from Impey tanking before, is it likely to damage the tanking or if I'm very careful do you think I could remove it without damage and re-tile over it. It does seem quite a thick membrane after looking at the Impey systems.
Anyone done this before and what would be the best way of going about it.
Cheers
John
Andy Tiler
1,043
manchester
View attachment 53544 View attachment 53545
Cheers
John
Unless you skim it with adhesive to fill them holes and tile that area with thinner mosaic?
John Benton
1,138
Leeds
That was one of my thoughts Andy, I've found a mosaic that really goes well with existing floor and wall tiles and customer likes them, but they are same thickness as tile that has just come off so I would need to remove the majority of it
John Benton
1,138
Leeds
It has also been tiled outside of the normal falls in the tray..
Yep, they weren't even close Dave so I would have to create new falls to the drain. If I go over the existing but would require a thinner mosaic
Andy Tiler
1,043
manchester
Try very carefully sanding it with a Fein
Would take a while though John!!
It will have stuck hard to the Impey kit. You'll rip the membrane and have to either re-tank or cover over the damage with a paint on kit/Impey patch in.
I've had to do this a few times and it's always a nightmare
John Benton
1,138
Leeds
That's just what I needed to hear, seriously, how difficult and easy it would be and would it damage the tanking not having done it before on the Impey. Now I have a better idea for costings.
Cheers
No probs. I done a shower last week. 2 mts of porc tiles on impey to come up. . . took a day with a sds!! The impey makes the adhesive come up in 50p size bits and then you have to get the snots off the formed tray so you can re-tank and get the correct falls.
Good luck with it
John Benton
1,138
Leeds
Good luck with it
Did you re-tank with paint on or with Impey again?
K
kaharrison9
Hi John.I had one of these a while ago to do. I think the hardest part is done and that is getting the tiles up without any real damage. I would use a stone polisher maybe around 240 grit on slow speed and gentle sand the addy down. Then check for any holes and screed over the holes with rapid. prime then tank and apply a 1mm fleece over and re tank immediately over the top (I used the mira tanking kit with there safecoat fleece from pure adhesion Harrogate).The tray is now repaired and fully tanked and ready to go. Do get one of those dust door protectors as the sanding will throw up some dust. If you need to borrow my sanding kit give us a ring or if nearby by i'll pop over and help out. though I am on holiday next week. Wet trays with thought to an exstent can be repaired Kevin
John Benton
1,138
Leeds
Cheers Kevin, and thanks for the call earlier this evening. Enjoy your hols.
Reply to Advice requiredpls in the Canada Tile Advice area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
John Benton
Leeds
Advice requiredpls
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
