Matthew77
Hi all i'm looking for advice on what tile cutter i should go for. I've been looking at the Rubi range of cutters, but am now getting a little confused as they seem to have alot of different models and sizes.
Size wise what do most of you use as i guess a bigger the tile cutter will cut bigger tiles but generally a big cutter is going to be a bit of a hassle to work with in smaller spaces. So what would be an ideal size for most of you?
Can someone pls explain the difference between the ts range and tx range?
Matthew
Matthew
