Discuss Alternative to Hardiback in the Canada Tile Advice area at TilersForums.com.
Perfect Tiling
Why do you mention 12mm ply...the BS is 15mm minimum! You can always do what a lot of tilers are doing....use either 6mm ply or nothing at all!!! Neither will work very well and you will need to go back and repair it or just walk away. Save the agro and use 6mm hardiebacker...it does what it says! End of.
Mr Tiler
I'm not a fan of no more ply, it's too shiny which in my mind doesn't make the bond as good, and brittle, which makes it split when screwing near the edges. Just my opinion but, hardiebacker is the only board I like and trust out of the ones I've tried.
so far ive only used hardi 6mm and that was a bit hard to get each screw going even got a warwound on the thumb lol. but seems the most ideal and the centres were already there for me. I didn't find it hard to cut and snap... but I havnt tried the 12mm yet! lol
beanz
Berkshire
Yeah I know what your saying about screwing near the edges, but I found the 12mm Hardie the same until I started countersinking.. The countersink didn't last too long either lol! I didn't get any comeback with the No More Ply, but they were only 12x10 ceramics, so no weight to speak of...
too many health concerns with the Hardie for my liking...
beanz
Berkshire
Just turbo golds.. But now I think about it, I was screwing to that crap Ali stud work, which was actually my reason for countersinking... It wasn't for the cracked corner, although that did happen, and could've been more about being too close to the edge.. Funny how you can remember something completely differently, then something else triggers a more accurate memory!?!?!
Reply to Alternative to Hardiback in the Canada Tile Advice area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
